Noctua
Light Wings PWM HS
NF-A14 FLX
210 g
210 g
300 U/min
900 U/min
2500 U/min
1200 U/min
1.4 W
5.4 W
52.3 CFM
68.0 CFM
88.9 m³/h
115.5 m³/h
2.60 mmH2O
1.51 mmH2O
31.0 dBA
19.2 dBA
Beige
Braun
Braun
4.6 V
4.2 V
608 U/min
381 U/min
565 U/min
469 U/min
2489 U/min
1199 U/min
248 U/min
32.5 CFM
+64.4 %
53.5 CFM
18.5 CFM
+78.4 %
33.0 CFM
18.9 CFM
+67.1 %
31.7 CFM
17.7 CFM
+70.2 %
30.1 CFM
55.3 m³/h
+64.4 %
90.9 m³/h
31.4 m³/h
+78.3 %
56.0 m³/h
32.2 m³/h
+67.1 %
53.8 m³/h
30.1 m³/h
+70.1 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+82.0 %
0.91 mmH2O
0.40 mmH2O
+25.0 %
+66.7 %
0.30 mmH2O
+28.6 %
0.09 hPa
+80.0 %
0.09 hPa
+25.0 %
+66.7 %
0.03 hPa
33.7
-1.5 %
34.2
31.6
-25.8 %
42.6
32
-21.6 %
40.8
30.7
-23.1 %
39.9
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
