Cooler Master
Light Wings PWM
Masterfan MF120 Halo
205 g
180 g
100 U/min
650 U/min
1700 U/min
1800 U/min
0.8 W
4.6 W
41.5 CFM
47.2 CFM
70.5 m³/h
1.66 mmH2O
20.6 dBA
30.0 dBA
Grau
Halbtransparent
3.3 V
369 U/min
166 U/min
350 U/min
590 U/min
1680 U/min
1792 U/min
134 U/min
33.8 CFM
+36.4 %
24.8 CFM
19.89
19.89
19.4 CFM
+4.2 %
20.2 CFM
18.5 CFM
+7.2 %
17.2 CFM
57.4 m³/h
+36.3 %
42.1 m³/h
33.8
33.8
33.0 m³/h
+5.1 %
31.4 m³/h
31.4 m³/h
+7.2 %
29.3 m³/h
+77.5 %
0.40 mmH2O
+62.0 %
+25.0 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+75.0 %
+60.0 %
+25.0 %
+50.0 %
29.5
-22.0 %
37.8
29.6
-18.7 %
36.4
31.5
-13.7 %
36.5
32.4
-9.0 %
35.6
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
