Lian Li
Light Wings PWM
UNI FAN SL-INF 120
205 g
210 g
100 U/min
1700 U/min
2100 U/min
0.8 W
4.6 W
3.0 W
41.5 CFM
61.3 CFM
70.5 m³/h
104.1 m³/h
1.66 mmH2O
2.66 mmH2O
20.6 dBA
29.0 dBA
3.5 V
369 U/min
913 U/min
350 U/min
742 U/min
290 U/min
298 U/min
1680 U/min
2134 U/min
134 U/min
886 U/min
33.8 CFM
+12.8 %
30.0 CFM
19.9 CFM
+19.8 %
23.8 CFM
19.4 CFM
+10.9 %
21.5 CFM
18.5 CFM
+20.7 %
22.3 CFM
57.4 m³/h
+12.8 %
50.9 m³/h
33.8 m³/h
+19.8 %
40.5 m³/h
33.0 m³/h
+10.9 %
36.6 m³/h
31.4 m³/h
+20.7 %
37.9 m³/h
0.71
0.71
+42.0 %
+2.0 %
0.51 mmH2O
+19.6 %
0.51 mmH2O
+0.5 %
+39.3 %
+0.0 %
+20.0 %
29.5
-9.5 %
32.6
29.6
-11.6 %
33.5
31.5
-3.4 %
32.6
32.4
-3.3 %
33.5
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
  • 290
  • 490
  • 690
  • 890
  • 1090
  • 1290
  • 1490
  • 1690
  • 1890
  • 2090
