Blacknoise
Light Wings PWM
NB-eLoop X PWM B12xP ARGB
205 g
120 g
100 U/min
400 U/min
1700 U/min
0.8 W
4.6 W
41.5 CFM
77.9 CFM
70.5 m³/h
132.4 m³/h
1.66 mmH2O
3.02 mmH2O
20.6 dBA
28.4 dBA
Grau
3.4 V
369 U/min
294 U/min
350 U/min
138 U/min
1680 U/min
2002 U/min
134 U/min
33.8 CFM
+20.0 %
40.5 CFM
19.9 CFM
+25.1 %
24.9 CFM
19.4 CFM
+18.5 %
23.0 CFM
18.5 CFM
+13.7 %
21.0 CFM
57.4 m³/h
+20.0 %
68.9 m³/h
33.8 m³/h
+25.1 %
42.3 m³/h
33.0 m³/h
+18.5 %
39.1 m³/h
31.4 m³/h
+13.7 %
35.7 m³/h
+101.4 %
1.43 mmH2O
+62.0 %
+22.0 %
+22.0 %
+100.0 %
0.14 hPa
+60.0 %
+20.0 %
+20.0 %
29.5
-14.2 %
34.4
29.6
-18.9 %
36.5
31.5
-12.3 %
35.9
32.4
-10.2 %
36.1
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
