Noctua
Light Wings PWM
NF-A14 FLX
205 g
210 g
100 U/min
900 U/min
1700 U/min
1200 U/min
0.8 W
4.6 W
41.5 CFM
68.0 CFM
70.5 m³/h
115.5 m³/h
1.66 mmH2O
1.51 mmH2O
20.6 dBA
19.2 dBA
Beige
Braun
Braun
4.6 V
4.2 V
369 U/min
381 U/min
350 U/min
469 U/min
1680 U/min
1199 U/min
134 U/min
33.8 CFM
+58.4 %
53.5 CFM
19.9 CFM
+65.7 %
33.0 CFM
19.4 CFM
+63.1 %
31.7 CFM
18.5 CFM
+63.1 %
30.1 CFM
57.4 m³/h
+58.4 %
90.9 m³/h
33.8 m³/h
+65.7 %
56.0 m³/h
33.0 m³/h
+63.0 %
53.8 m³/h
31.4 m³/h
+63.1 %
51.2 m³/h
+28.2 %
0.91 mmH2O
+82.0 %
0.91 mmH2O
0.5
0.5
+103.3 %
0.30 mmH2O
+28.6 %
0.09 hPa
+80.0 %
0.09 hPa
0.05
0.05
+100.0 %
0.03 hPa
29.5
-13.7 %
34.2
29.6
-30.5 %
42.6
31.5
-22.8 %
40.8
32.4
-18.8 %
39.9
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
