Alphacool
Corsair
Rise Aurora
LL140 RGB
210 g
600 U/min
1300 U/min
6.6 W
90.7 CFM
51.5 CFM
154.1 m³/h
87.5 m³/h
2.20 mmH2O
1.52 mmH2O
38.4 dBA
25.0 dBA
Halbtransparent
2.9 V
2.9 V
883 U/min
226 U/min
553 U/min
378 U/min
331 U/min
145 U/min
2108 U/min
1319 U/min
677 U/min
50.4 CFM
+11.9 %
45.0 CFM
26.7 CFM
+6.4 %
28.4 CFM
21.8 CFM
+12.2 %
24.5 CFM
20.5 CFM
+28.7 %
26.4 CFM
85.6 m³/h
+11.9 %
76.5 m³/h
45.3 m³/h
+6.4 %
48.2 m³/h
37.1 m³/h
+12.1 %
41.6 m³/h
34.9 m³/h
+28.7 %
44.9 m³/h
1.01 mmH2O
+68.3 %
0.60 mmH2O
0.60 mmH2O
+20.0 %
+42.0 %
+32.8 %
+66.7 %
+20.0 %
+40.0 %
+33.3 %
39.4
-10.4 %
35.3
39.2
-5.9 %
36.9
39
-12.8 %
34
37.7
-7.7 %
34.8
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
