Alphacool
Noctua
Rise Aurora
NF-A14 FLX
210 g
900 U/min
1200 U/min
6.6 W
90.7 CFM
68.0 CFM
154.1 m³/h
115.5 m³/h
2.20 mmH2O
1.51 mmH2O
38.4 dBA
19.2 dBA
Beige
Braun
Braun
4.6 V
2.9 V
4.2 V
883 U/min
381 U/min
553 U/min
469 U/min
331 U/min
145 U/min
2108 U/min
1199 U/min
677 U/min
50.4 CFM
+6.2 %
53.5 CFM
26.7 CFM
+23.6 %
33.0 CFM
21.8 CFM
+45.1 %
31.7 CFM
20.5 CFM
+46.7 %
30.1 CFM
85.6 m³/h
+6.2 %
90.9 m³/h
45.3 m³/h
+23.6 %
56.0 m³/h
37.1 m³/h
+45.0 %
53.8 m³/h
34.9 m³/h
+46.7 %
51.2 m³/h
1.01 mmH2O
+11.0 %
0.91 mmH2O
0.60 mmH2O
+51.7 %
0.91 mmH2O
+42.0 %
+170.0 %
0.30 mmH2O
+11.1 %
0.09 hPa
+50.0 %
0.09 hPa
+40.0 %
+166.7 %
0.03 hPa
39.4
-13.2 %
34.2
39.2
-8.0 %
42.6
39
-4.4 %
40.8
37.7
-5.5 %
39.9
  • 331
  • 531
  • 731
  • 931
  • 1131
  • 1331
  • 1531
  • 1731
  • 1931
