Alpenföhn
MSI
Wing Boost 3 ARGB High Speed
MEG Silent Gale P12
27.5 mm
208 g
209 g
500 U/min
2200 U/min
0.7 W
4.1 W
1.4 W
77.9 CFM
56.2 CFM
132.4 m³/h
95.5 m³/h
3.24 mmH2O
2.21 mmH2O
36.8 dBA
22.7 dBA
Silber
2.7 V
5.5 V
2.5 V
4.3 V
485 U/min
906 U/min
302 U/min
742 U/min
194 U/min
186 U/min
2281 U/min
1980 U/min
458 U/min
512 U/min
32.8 CFM
+5.3 %
31.1 CFM
20.8 CFM
+3.4 %
21.5 CFM
19.4 CFM
+13.6 %
22.1 CFM
17.9 CFM
+9.6 %
19.7 CFM
55.7 m³/h
+5.3 %
52.9 m³/h
35.4 m³/h
+3.4 %
36.6 m³/h
33.0 m³/h
+13.6 %
37.5 m³/h
30.5 m³/h
+9.5 %
33.4 m³/h
1.83 mmH2O
+101.1 %
0.91 mmH2O
1.73 mmH2O
+113.6 %
1.73 mmH2O
+113.6 %
1.01 mmH2O
+24.7 %
0.18 hPa
+100.0 %
0.09 hPa
0.17 hPa
+112.5 %
0.17 hPa
+112.5 %
+25.0 %
40.9
-23.7 %
31.2
40.5
-14.1 %
34.8
39
-11.3 %
34.6
37.5
-11.7 %
33.1
  • 302
  • 502
  • 702
  • 902
  • 1102
  • 1302
  • 1502
  • 1702
  • 1902
  • 2102
