MSI
Blacknoise
MEG Silent Gale P12
B12x-PS-BL PWM ARGB
27.5 mm
209 g
120 g
1500 U/min
0.7 W
1.4 W
56.2 CFM
58.1 CFM
95.5 m³/h
98.7 m³/h
2.21 mmH2O
1.80 mmH2O
22.7 dBA
21.2 dBA
5.5 V
3.3 V
4.3 V
906 U/min
386 U/min
742 U/min
570 U/min
194 U/min
186 U/min
1980 U/min
1491 U/min
512 U/min
31.1 CFM
+17.6 %
36.6 CFM
21.5 CFM
+9.3 %
23.5 CFM
22.1 CFM
+8.5 %
23.9 CFM
19.7 CFM
+15.7 %
22.8 CFM
52.9 m³/h
+17.6 %
62.2 m³/h
36.6 m³/h
+9.3 %
40.0 m³/h
37.5 m³/h
+6.1 %
39.8 m³/h
33.4 m³/h
+15.9 %
38.7 m³/h
0.91 mmH2O
+23.1 %
1.12 mmH2O
+14.1 %
+32.8 %
+14.1 %
0.09 hPa
+22.2 %
0.11 hPa
+14.3 %
+33.3 %
+14.3 %
31.2
-19.4 %
38.7
34.8
-8.2 %
37.9
34.6
-11.5 %
39.1
33.1
-10.5 %
37
