MSI
Cooler Master
MEG Silent Gale P12
Masterfan MF120 Halo
27.5 mm
209 g
180 g
650 U/min
1800 U/min
0.7 W
1.4 W
56.2 CFM
47.2 CFM
95.5 m³/h
2.21 mmH2O
22.7 dBA
30.0 dBA
Grau
Halbtransparent
5.5 V
3.3 V
4.3 V
906 U/min
166 U/min
742 U/min
590 U/min
194 U/min
186 U/min
1980 U/min
1792 U/min
512 U/min
31.1 CFM
+25.7 %
24.8 CFM
21.5 CFM
+8.3 %
19.9 CFM
22.1 CFM
+9.0 %
20.2 CFM
19.7 CFM
+14.2 %
17.2 CFM
52.9 m³/h
+25.7 %
42.1 m³/h
36.6 m³/h
+8.3 %
33.8 m³/h
37.5 m³/h
+19.4 %
31.4 m³/h
33.4 m³/h
+14.0 %
29.3 m³/h
0.91 mmH2O
+127.5 %
0.40 mmH2O
0.81
0.81
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
0.09 hPa
+125.0 %
0.08
0.08
+100.0 %
+100.0 %
31.2
-17.5 %
37.8
34.8
-4.4 %
36.4
34.6
-5.2 %
36.5
33.1
-7.0 %
35.6
