MSI
Sharkoon
MEG Silent Gale P12
Silent Storm PWM RGB Fan
27.5 mm
209 g
135 g
400 U/min
1400 U/min
0.7 W
1.4 W
2.2 W
56.2 CFM
95.5 m³/h
93.6 m³/h
2.21 mmH2O
22.7 dBA
20.4 dBA
5.5 V
3.6 V
4.3 V
906 U/min
585 U/min
742 U/min
561 U/min
194 U/min
186 U/min
1980 U/min
1374 U/min
513 U/min
512 U/min
31.1 CFM
+9.3 %
34.0 CFM
21.5 CFM
+10.6 %
19.5 CFM
22.1 CFM
+10.6 %
24.4 CFM
19.7 CFM
+9.5 %
21.5 CFM
52.9 m³/h
+9.3 %
57.8 m³/h
36.6 m³/h
+10.6 %
33.1 m³/h
37.5 m³/h
+10.7 %
41.5 m³/h
33.4 m³/h
+9.6 %
36.6 m³/h
0.91 mmH2O
+28.2 %
+32.8 %
+32.8 %
+32.8 %
0.09 hPa
+28.6 %
+33.3 %
+33.3 %
+33.3 %
31.2
-1.6 %
31.7
34.8
-16.1 %
29.2
34.6
-20.5 %
27.5
33.1
-18.1 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
