MSI
Corsair
MEG Silent Gale P12
QL120 RGB
27.5 mm
209 g
163 g
500 U/min
1500 U/min
0.7 W
1.4 W
56.2 CFM
41.8 CFM
95.5 m³/h
2.21 mmH2O
1.55 mmH2O
22.7 dBA
26.0 dBA
Silber
Halbtransparent
5.5 V
3.0 V
4.3 V
906 U/min
245 U/min
742 U/min
472 U/min
194 U/min
186 U/min
1980 U/min
1600 U/min
512 U/min
31.1 CFM
+12.1 %
27.8 CFM
21.5 CFM
+4.6 %
20.6 CFM
22.1 CFM
+15.1 %
19.2 CFM
19.7 CFM
+14.2 %
17.2 CFM
52.9 m³/h
+12.1 %
47.2 m³/h
36.6 m³/h
+4.6 %
35.0 m³/h
37.5 m³/h
+15.0 %
32.6 m³/h
33.4 m³/h
+14.0 %
29.3 m³/h
0.91 mmH2O
+11.0 %
1.01 mmH2O
+62.0 %
+62.0 %
+102.5 %
0.40 mmH2O
0.09 hPa
+11.1 %
+60.0 %
+60.0 %
+100.0 %
31.2
-18.8 %
38.4
34.8
-9.1 %
38.3
34.6
-3.6 %
35.9
33.1
-7.5 %
35.8
