MSI
Blacknoise
MEG Silent Gale P12
NB-eLoop X PWM B12xP ARGB
27.5 mm
209 g
120 g
400 U/min
0.7 W
1.4 W
56.2 CFM
77.9 CFM
95.5 m³/h
132.4 m³/h
2.21 mmH2O
3.02 mmH2O
22.7 dBA
28.4 dBA
Grau
5.5 V
3.4 V
4.3 V
906 U/min
294 U/min
742 U/min
138 U/min
194 U/min
186 U/min
1980 U/min
2002 U/min
512 U/min
31.1 CFM
+30.3 %
40.5 CFM
21.5 CFM
+15.6 %
24.9 CFM
22.1 CFM
+4.3 %
23.0 CFM
19.7 CFM
+6.8 %
21.0 CFM
52.9 m³/h
+30.2 %
68.9 m³/h
36.6 m³/h
+15.6 %
42.3 m³/h
37.5 m³/h
+4.3 %
39.1 m³/h
33.4 m³/h
+6.9 %
35.7 m³/h
0.91 mmH2O
+57.1 %
1.43 mmH2O
0.81
0.81
+32.8 %
+62.0 %
0.09 hPa
+55.6 %
0.14 hPa
0.08
0.08
+33.3 %
+60.0 %
31.2
-9.3 %
34.4
34.8
-4.7 %
36.5
34.6
-3.6 %
35.9
33.1
-8.3 %
36.1
