MSI
Alpenföhn
MEG Silent Gale P12
Wing Boost 3
27.5 mm
209 g
122 g
400 U/min
1050 U/min
0.7 W
1.4 W
56.2 CFM
60.6 CFM
95.5 m³/h
103.0 m³/h
2.21 mmH2O
22.7 dBA
22.0 dBA
5.5 V
4.7 V
4.3 V
2.0 V
906 U/min
443 U/min
742 U/min
174 U/min
194 U/min
186 U/min
1980 U/min
1075 U/min
477 U/min
512 U/min
31.1 CFM
+58.3 %
49.3 CFM
21.5 CFM
+9.0 %
23.5 CFM
22.1 CFM
+6.4 %
23.5 CFM
19.7 CFM
+5.0 %
20.7 CFM
52.9 m³/h
+58.2 %
83.7 m³/h
36.6 m³/h
+9.0 %
39.9 m³/h
37.5 m³/h
+6.4 %
39.9 m³/h
33.4 m³/h
+5.1 %
35.1 m³/h
0.91 mmH2O
+79.1 %
1.63 mmH2O
+32.8 %
+62.0 %
+102.5 %
0.40 mmH2O
0.09 hPa
+77.8 %
0.16 hPa
+33.3 %
+60.0 %
+100.0 %
31.2
-30.0 %
44.6
34.8
-26.4 %
47.3
34.6
-24.3 %
45.7
33.1
-23.6 %
43.3
