MSI
Arctic
MEG Silent Gale P12
P14 PWM
27.5 mm
209 g
194 g
200 U/min
1700 U/min
0.7 W
1.4 W
56.2 CFM
72.8 CFM
95.5 m³/h
123.8 m³/h
2.21 mmH2O
2.40 mmH2O
22.7 dBA
5.5 V
3.8 V
4.3 V
906 U/min
395 U/min
742 U/min
481 U/min
194 U/min
186 U/min
1980 U/min
1733 U/min
512 U/min
31.1 CFM
+46.7 %
45.7 CFM
21.5 CFM
+25.7 %
27.1 CFM
22.1 CFM
+16.8 %
25.8 CFM
19.7 CFM
+37.2 %
27.0 CFM
52.9 m³/h
+46.7 %
77.6 m³/h
36.6 m³/h
+25.7 %
46.0 m³/h
37.5 m³/h
+16.8 %
43.8 m³/h
33.4 m³/h
+37.4 %
45.9 m³/h
0.91 mmH2O
+51.7 %
0.60 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
0.09 hPa
+50.0 %
+100.0 %
+100.0 %
+100.0 %
31.2
-1.6 %
30.7
34.8
-12.6 %
30.4
34.6
-13.3 %
30
33.1
-7.6 %
30.6
