MSI
Corsair
MEG Silent Gale P12
LL140 RGB
27.5 mm
209 g
210 g
600 U/min
1300 U/min
0.7 W
1.4 W
56.2 CFM
51.5 CFM
95.5 m³/h
87.5 m³/h
2.21 mmH2O
1.52 mmH2O
22.7 dBA
25.0 dBA
Halbtransparent
5.5 V
4.3 V
2.9 V
906 U/min
226 U/min
742 U/min
378 U/min
194 U/min
186 U/min
1980 U/min
1319 U/min
512 U/min
31.1 CFM
+44.6 %
45.0 CFM
21.5 CFM
+31.7 %
28.4 CFM
22.1 CFM
+10.9 %
24.5 CFM
19.7 CFM
+34.3 %
26.4 CFM
52.9 m³/h
+44.6 %
76.5 m³/h
36.6 m³/h
+31.7 %
48.2 m³/h
37.5 m³/h
+10.9 %
41.6 m³/h
33.4 m³/h
+34.4 %
44.9 m³/h
0.91 mmH2O
+51.7 %
0.60 mmH2O
+62.0 %
+62.0 %
+32.8 %
0.09 hPa
+50.0 %
+60.0 %
+60.0 %
+33.3 %
31.2
-11.6 %
35.3
34.8
-5.7 %
36.9
34.6
-1.7 %
34
33.1
-4.9 %
34.8
