MSI
Cooler Master
MEG Silent Gale P12
Sickleflow 140 ARGB
27.5 mm
209 g
195 g
650 U/min
1400 U/min
0.7 W
1.4 W
56.2 CFM
67.0 CFM
95.5 m³/h
113.8 m³/h
2.21 mmH2O
2.25 mmH2O
22.7 dBA
27.0 dBA
Halbtransparent
5.5 V
5.5 V
4.3 V
2.9 V
906 U/min
599 U/min
742 U/min
495 U/min
194 U/min
186 U/min
1980 U/min
1374 U/min
512 U/min
31.1 CFM
+45.6 %
45.3 CFM
21.5 CFM
+30.3 %
28.1 CFM
22.1 CFM
+18.1 %
26.1 CFM
19.7 CFM
+37.2 %
27.0 CFM
52.9 m³/h
+45.6 %
77.0 m³/h
36.6 m³/h
+30.3 %
47.7 m³/h
37.5 m³/h
+18.1 %
44.3 m³/h
33.4 m³/h
+37.4 %
45.9 m³/h
0.91 mmH2O
+82.0 %
+62.0 %
+62.0 %
+62.0 %
0.09 hPa
+80.0 %
+60.0 %
+60.0 %
+60.0 %
31.2
-12.1 %
35.5
34.8
-6.5 %
37.2
34.6
-5.2 %
32.8
33.1
-1.2 %
33.5
