MSI
Noctua
MEG Silent Gale P12
NF-A14 FLX
27.5 mm
209 g
210 g
900 U/min
1200 U/min
0.7 W
1.4 W
56.2 CFM
68.0 CFM
95.5 m³/h
115.5 m³/h
2.21 mmH2O
1.51 mmH2O
22.7 dBA
19.2 dBA
Beige
Braun
Braun
5.5 V
4.6 V
4.3 V
4.2 V
906 U/min
381 U/min
742 U/min
469 U/min
194 U/min
186 U/min
1980 U/min
1199 U/min
512 U/min
31.1 CFM
+71.9 %
53.5 CFM
21.5 CFM
+53.0 %
33.0 CFM
22.1 CFM
+43.5 %
31.7 CFM
19.7 CFM
+53.1 %
30.1 CFM
52.9 m³/h
+71.8 %
90.9 m³/h
36.6 m³/h
+53.0 %
56.0 m³/h
37.5 m³/h
+43.5 %
53.8 m³/h
33.4 m³/h
+53.3 %
51.2 m³/h
0.91
0.91
+12.3 %
0.91 mmH2O
+62.0 %
+170.0 %
0.30 mmH2O
0.09
0.09
+12.5 %
0.09 hPa
+60.0 %
+166.7 %
0.03 hPa
31.2
-8.8 %
34.2
34.8
-18.3 %
42.6
34.6
-15.2 %
40.8
33.1
-17.0 %
39.9
