MSI
Thermaltake
MEG Silent Gale P12
27.5 mm
209 g
212 g
500 U/min
0.7 W
1.4 W
56.2 CFM
58.4 CFM
95.5 m³/h
99.1 m³/h
2.21 mmH2O
2.41 mmH2O
22.7 dBA
22.3 dBA
Grau
5.5 V
4.3 V
906 U/min
391 U/min
742 U/min
413 U/min
194 U/min
186 U/min
1980 U/min
1950 U/min
512 U/min
31.1 CFM
+6.6 %
33.2 CFM
21.5 CFM
+16.9 %
25.2 CFM
22.1 CFM
+10.9 %
24.5 CFM
19.7 CFM
+5.8 %
20.8 CFM
52.9 m³/h
+6.6 %
56.4 m³/h
36.6 m³/h
+16.9 %
42.8 m³/h
37.5 m³/h
+10.9 %
41.6 m³/h
33.4 m³/h
+6.0 %
35.4 m³/h
0.91 mmH2O
+102.2 %
1.84 mmH2O
0.81
0.81
+62.0 %
+102.5 %
0.40 mmH2O
0.09 hPa
+100.5 %
0.18 hPa
+0.7 %
+63.2 %
+103.9 %
31.2
-16.6 %
37.4
34.8
-4.7 %
36.5
34.6
-3.9 %
36
33.1
-8.6 %
36.2
