Asus
Blacknoise
NB-eLoop X PWM B12xP ARGB
145 g
120 g
250 U/min
400 U/min
1800 U/min
62.5 CFM
77.9 CFM
106.2 m³/h
132.4 m³/h
3.07 mmH2O
3.02 mmH2O
22.5 dBA
28.4 dBA
Grau
3.4 V
409 U/min
294 U/min
419 U/min
138 U/min
208 U/min
129 U/min
1778 U/min
2002 U/min
308 U/min
23.9 CFM
+69.3 %
40.5 CFM
18.7 CFM
+33.0 %
24.9 CFM
18.5 CFM
+24.5 %
23.0 CFM
17.7 CFM
+18.6 %
21.0 CFM
40.7 m³/h
+69.3 %
68.9 m³/h
31.8 m³/h
+33.0 %
42.3 m³/h
31.4 m³/h
+24.5 %
39.1 m³/h
30.1 m³/h
+18.6 %
35.7 m³/h
0.92 mmH2O
+55.8 %
1.43 mmH2O
0.92 mmH2O
+13.3 %
0.82 mmH2O
+33.7 %
+42.8 %
0.09 hPa
+55.6 %
0.14 hPa
0.09 hPa
+12.5 %
+33.3 %
+40.0 %
34.6
-0.6 %
34.4
38.9
-6.2 %
36.5
38.4
-6.5 %
35.9
38.4
-6.0 %
36.1
