Asus
Noctua
NF-A14 FLX
145 g
210 g
250 U/min
900 U/min
1800 U/min
1200 U/min
62.5 CFM
68.0 CFM
106.2 m³/h
115.5 m³/h
3.07 mmH2O
1.51 mmH2O
22.5 dBA
19.2 dBA
Beige
Braun
Braun
4.6 V
4.2 V
409 U/min
381 U/min
419 U/min
469 U/min
208 U/min
129 U/min
1778 U/min
1199 U/min
308 U/min
23.9 CFM
+123.4 %
53.5 CFM
18.7 CFM
+76.2 %
33.0 CFM
18.5 CFM
+71.4 %
31.7 CFM
17.7 CFM
+70.2 %
30.1 CFM
40.7 m³/h
+123.3 %
90.9 m³/h
31.8 m³/h
+76.1 %
56.0 m³/h
31.4 m³/h
+71.3 %
53.8 m³/h
30.1 m³/h
+70.1 %
51.2 m³/h
0.92 mmH2O
+0.9 %
0.91 mmH2O
0.92 mmH2O
+0.9 %
0.91 mmH2O
0.82 mmH2O
+63.2 %
+137.9 %
0.30 mmH2O
0.09
0.09
0.09
0.09
+60.0 %
+133.3 %
0.03 hPa
34.6
-1.2 %
34.2
38.9
-8.7 %
42.6
38.4
-5.9 %
40.8
38.4
-3.8 %
39.9
