Blacknoise
Sharkoon
NB-eLoop X PWM B12xP ARGB
Silent Storm PWM RGB Fan
120 g
168 g
400 U/min
400 U/min
1400 U/min
2.6 W
77.9 CFM
132.4 m³/h
121.9 m³/h
3.02 mmH2O
1.47 mmH2O
28.4 dBA
34.7 dBA
Grau
3.4 V
1.9 V
294 U/min
506 U/min
138 U/min
54 U/min
2002 U/min
1413 U/min
440 U/min
40.5 CFM
+1.3 %
41.1 CFM
24.9 CFM
+28.4 %
31.9 CFM
23.0 CFM
+33.2 %
30.7 CFM
21.0 CFM
+59.9 %
33.6 CFM
68.9 m³/h
+1.3 %
69.8 m³/h
42.3 m³/h
+28.4 %
54.3 m³/h
39.1 m³/h
+33.2 %
52.1 m³/h
35.7 m³/h
+59.9 %
57.1 m³/h
1.43 mmH2O
+76.5 %
+14.1 %
+16.4 %
+2.0 %
0.51 mmH2O
0.14 hPa
+75.0 %
+14.3 %
+16.7 %
0.05
0.05
34.4
-5.2 %
32.6
36.5
-10.4 %
32.7
35.9
-7.5 %
33.2
36.1
-11.1 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
