Blacknoise
Thermalright
NB-eLoop X PWM B12xP ARGB
TL-B12 Extreme
25.6 mm
120 g
215 g
400 U/min
550 U/min
3150 U/min
1.0 W
4.2 W
77.9 CFM
112.0 CFM
132.4 m³/h
190.3 m³/h
3.02 mmH2O
5.00 mmH2O
28.4 dBA
40.5 dBA
Grau
Rot, Weiß
3.4 V
1.8 V
1.4 V
294 U/min
293 U/min
138 U/min
163 U/min
2002 U/min
2857 U/min
554 U/min
40.5 CFM
+28.3 %
31.6 CFM
24.9 CFM
+4.9 %
23.7 CFM
23.0 CFM
+3.2 %
22.3 CFM
21.0 CFM
+0.3 %
21.1 CFM
68.9 m³/h
+28.3 %
53.7 m³/h
42.3 m³/h
+5.0 %
40.3 m³/h
39.1 m³/h
+3.2 %
37.9 m³/h
35.7 m³/h
+0.3 %
35.8 m³/h
1.43 mmH2O
+101.4 %
+14.1 %
+32.8 %
+42.0 %
0.14 hPa
+100.0 %
+14.3 %
+33.3 %
+40.0 %
34.4
-5.8 %
32.4
36.5
-14.8 %
31.1
35.9
-9.5 %
32.5
36.1
-15.5 %
30.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
