Blacknoise
Sharkoon
NB-eLoop X PWM B12xP ARGB
Silent Storm PWM RGB Fan
120 g
135 g
400 U/min
400 U/min
1400 U/min
2.2 W
77.9 CFM
132.4 m³/h
93.6 m³/h
3.02 mmH2O
28.4 dBA
20.4 dBA
Grau
3.4 V
3.6 V
294 U/min
585 U/min
138 U/min
561 U/min
2002 U/min
1374 U/min
513 U/min
40.5 CFM
+19.2 %
34.0 CFM
24.9 CFM
+27.8 %
19.5 CFM
23.0 CFM
+6.1 %
24.4 CFM
21.0 CFM
+2.5 %
21.5 CFM
68.9 m³/h
+19.2 %
57.8 m³/h
42.3 m³/h
+27.8 %
33.1 m³/h
39.1 m³/h
+6.1 %
41.5 m³/h
35.7 m³/h
+2.5 %
36.6 m³/h
1.43 mmH2O
+101.4 %
+32.8 %
0.61
0.61
+22.0 %
0.14 hPa
+100.0 %
+33.3 %
0.06
0.06
+20.0 %
34.4
-7.8 %
31.7
36.5
-20.0 %
29.2
35.9
-23.4 %
27.5
36.1
-24.9 %
27.1
  • 561
  • 761
  • 961
  • 1161
  • 1361
