Blacknoise
Corsair
NB-eLoop X PWM B12xP ARGB
ML 120 RGB Elite
120 g
186 g
400 U/min
450 U/min
1.6 W
77.9 CFM
58.1 CFM
132.4 m³/h
98.7 m³/h
3.02 mmH2O
2.90 mmH2O
28.4 dBA
30.4 dBA
Grau
3.4 V
3.0 V
294 U/min
510 U/min
138 U/min
450 U/min
169 U/min
84 U/min
2002 U/min
1993 U/min
40.5 CFM
+15.0 %
35.2 CFM
24.9 CFM
+2.9 %
24.2 CFM
23.0 CFM
+3.0 %
23.7 CFM
21.0 CFM
+1.4 %
21.3 CFM
68.9 m³/h
+15.0 %
59.9 m³/h
42.3 m³/h
+2.9 %
41.1 m³/h
39.1 m³/h
+3.1 %
40.3 m³/h
35.7 m³/h
+1.4 %
36.2 m³/h
1.43 mmH2O
+101.4 %
+32.8 %
0.61
0.61
+42.0 %
0.14 hPa
+100.0 %
+33.3 %
0.06
0.06
+40.0 %
34.4
-17.2 %
28.5
36.5
-19.2 %
29.5
35.9
-20.6 %
28.5
36.1
-23.0 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
