Blacknoise
Fractal
NB-eLoop X PWM B12xP ARGB
Prisma AL-12PWM
120 g
167 g
400 U/min
500 U/min
1.9 W
77.9 CFM
85.7 CFM
132.4 m³/h
145.7 m³/h
3.02 mmH2O
2.80 mmH2O
28.4 dBA
32.0 dBA
Grau
3.4 V
4.5 V
3.8 V
294 U/min
443 U/min
138 U/min
269 U/min
2002 U/min
2001 U/min
550 U/min
40.5 CFM
+28.3 %
31.6 CFM
24.9 CFM
+20.2 %
20.7 CFM
23.0 CFM
+10.5 %
20.8 CFM
21.0 CFM
+6.3 %
19.8 CFM
68.9 m³/h
+28.3 %
53.7 m³/h
42.3 m³/h
+20.2 %
35.2 m³/h
39.1 m³/h
+10.5 %
35.4 m³/h
35.7 m³/h
+6.3 %
33.6 m³/h
1.43 mmH2O
+76.5 %
+14.1 %
+16.4 %
+22.0 %
0.14 hPa
+75.0 %
+14.3 %
+16.7 %
+20.0 %
34.4
-3.1 %
35.5
36.5
-7.9 %
33.6
35.9
-11.1 %
31.9
36.1
-20.8 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
