Blacknoise
Corsair
NB-eLoop X PWM B12xP ARGB
QL120 RGB
120 g
163 g
400 U/min
500 U/min
1500 U/min
77.9 CFM
41.8 CFM
132.4 m³/h
3.02 mmH2O
1.55 mmH2O
28.4 dBA
26.0 dBA
Grau
Silber
Halbtransparent
3.4 V
3.0 V
294 U/min
245 U/min
138 U/min
472 U/min
2002 U/min
1600 U/min
40.5 CFM
+46.0 %
27.8 CFM
24.9 CFM
+20.8 %
20.6 CFM
23.0 CFM
+20.0 %
19.2 CFM
21.0 CFM
+21.9 %
17.2 CFM
68.9 m³/h
+46.0 %
47.2 m³/h
42.3 m³/h
+20.9 %
35.0 m³/h
39.1 m³/h
+19.9 %
32.6 m³/h
35.7 m³/h
+21.8 %
29.3 m³/h
1.43 mmH2O
+41.6 %
1.01 mmH2O
+62.0 %
+22.0 %
+25.0 %
0.40 mmH2O
0.14 hPa
+40.0 %
+60.0 %
+20.0 %
+25.0 %
34.4
-10.4 %
38.4
36.5
-4.7 %
38.3
35.9
35.9
36.1
-0.8 %
35.8
