Blacknoise
Arctic
NB-eLoop X PWM B12xP ARGB
P14 PWM
120 g
194 g
400 U/min
200 U/min
1700 U/min
77.9 CFM
72.8 CFM
132.4 m³/h
123.8 m³/h
3.02 mmH2O
2.40 mmH2O
28.4 dBA
Grau
3.4 V
3.8 V
294 U/min
395 U/min
138 U/min
481 U/min
2002 U/min
1733 U/min
40.5 CFM
+12.6 %
45.7 CFM
24.9 CFM
+8.8 %
27.1 CFM
23.0 CFM
+12.0 %
25.8 CFM
21.0 CFM
+28.6 %
27.0 CFM
68.9 m³/h
+12.6 %
77.6 m³/h
42.3 m³/h
+8.7 %
46.0 m³/h
39.1 m³/h
+12.0 %
43.8 m³/h
35.7 m³/h
+28.6 %
45.9 m³/h
1.43 mmH2O
+138.3 %
0.60 mmH2O
+102.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+25.0 %
0.40 mmH2O
0.14 hPa
+133.3 %
+100.0 %
+50.0 %
+25.0 %
34.4
-10.8 %
30.7
36.5
-16.7 %
30.4
35.9
-16.4 %
30
36.1
-15.2 %
30.6
