Alphacool
Arctic
Rise Aurora
P12 PWM PST RGB 0dB
180 g
159 g
2500 U/min
70.0 CFM
48.8 CFM
118.9 m³/h
82.9 m³/h
3.17 mmH2O
1.85 mmH2O
31.5 dBA
Grau
Halbtransparent
3.0 V
4.0 V
2.9 V
2.9 V
862 U/min
380 U/min
874 U/min
532 U/min
339 U/min
181 U/min
2775 U/min
1985 U/min
1045 U/min
29.0 CFM
+10.8 %
32.1 CFM
24.4 CFM
+2.0 %
23.9 CFM
23.5 CFM
+2.0 %
23.0 CFM
22.07
22.07
49.3 m³/h
+10.7 %
54.6 m³/h
41.5 m³/h
+2.0 %
40.7 m³/h
39.9 m³/h
+2.1 %
39.1 m³/h
37.5 m³/h
+0.0 %
37.5 m³/h
+32.4 %
0.51 mmH2O
+19.6 %
0.41 mmH2O
+49.5 %
0.41 mmH2O
+49.5 %
+33.3 %
+20.0 %
+50.0 %
+50.0 %
41.6
-18.8 %
33.8
41
-22.9 %
31.6
39.1
-16.4 %
32.7
40.5
-20.7 %
32.1
