Alphacool
Thermalright
Rise Aurora
TL-B12 Extreme
25.6 mm
180 g
215 g
550 U/min
2500 U/min
3150 U/min
1.0 W
4.2 W
70.0 CFM
112.0 CFM
118.9 m³/h
190.3 m³/h
3.17 mmH2O
5.00 mmH2O
31.5 dBA
40.5 dBA
Rot, Weiß
3.0 V
1.8 V
2.9 V
1.4 V
862 U/min
293 U/min
874 U/min
163 U/min
339 U/min
181 U/min
2775 U/min
2857 U/min
554 U/min
1045 U/min
29.0 CFM
+9.0 %
31.6 CFM
24.4 CFM
+3.0 %
23.7 CFM
23.5 CFM
+5.3 %
22.3 CFM
22.1 CFM
+4.7 %
21.1 CFM
49.3 m³/h
+8.9 %
53.7 m³/h
41.5 m³/h
+3.0 %
40.3 m³/h
39.9 m³/h
+5.3 %
37.9 m³/h
37.5 m³/h
+4.7 %
35.8 m³/h
+16.0 %
0.51 mmH2O
+39.3 %
0.41 mmH2O
+98.6 %
0.41 mmH2O
+74.1 %
+16.7 %
+40.0 %
+100.0 %
+75.0 %
41.6
-22.1 %
32.4
41
-24.1 %
31.1
39.1
-16.9 %
32.5
40.5
-24.7 %
30.5
  • 163
  • 363
  • 563
  • 763
  • 963
  • 1163
  • 1363
  • 1563
  • 1763
  • 1963
  • 2163
  • 2363
  • 2563
  • 2763
