Alphacool
Cooler Master
Rise Aurora
Sickleflow 140 ARGB
180 g
195 g
650 U/min
2500 U/min
1400 U/min
70.0 CFM
67.0 CFM
118.9 m³/h
113.8 m³/h
3.17 mmH2O
2.25 mmH2O
31.5 dBA
27.0 dBA
Halbtransparent
3.0 V
5.5 V
2.9 V
2.9 V
862 U/min
599 U/min
874 U/min
495 U/min
339 U/min
181 U/min
2775 U/min
1374 U/min
1045 U/min
29.0 CFM
+56.2 %
45.3 CFM
24.4 CFM
+14.9 %
28.1 CFM
23.5 CFM
+11.0 %
26.1 CFM
22.1 CFM
+22.4 %
27.0 CFM
49.3 m³/h
+56.2 %
77.0 m³/h
41.5 m³/h
+14.9 %
47.7 m³/h
39.9 m³/h
+11.0 %
44.3 m³/h
37.5 m³/h
+22.4 %
45.9 m³/h
+22.4 %
0.51 mmH2O
+2.0 %
0.41 mmH2O
+22.6 %
0.41 mmH2O
+22.6 %
+20.0 %
0.05
0.05
+25.0 %
+25.0 %
41.6
-14.7 %
35.5
41
-9.3 %
37.2
39.1
-16.1 %
32.8
40.5
-17.3 %
33.5
