Alphacool
Noctua
Rise Aurora
NF-A14 FLX
180 g
210 g
900 U/min
2500 U/min
1200 U/min
70.0 CFM
68.0 CFM
118.9 m³/h
115.5 m³/h
3.17 mmH2O
1.51 mmH2O
31.5 dBA
19.2 dBA
Beige
Braun
Braun
3.0 V
4.6 V
2.9 V
4.2 V
862 U/min
381 U/min
874 U/min
469 U/min
339 U/min
181 U/min
2775 U/min
1199 U/min
1045 U/min
29.0 CFM
+84.4 %
53.5 CFM
24.4 CFM
+35.0 %
33.0 CFM
23.5 CFM
+34.9 %
31.7 CFM
22.1 CFM
+36.5 %
30.1 CFM
49.3 m³/h
+84.4 %
90.9 m³/h
41.5 m³/h
+34.9 %
56.0 m³/h
39.9 m³/h
+34.8 %
53.8 m³/h
37.5 m³/h
+36.5 %
51.2 m³/h
+48.7 %
0.91 mmH2O
0.51 mmH2O
+78.5 %
0.91 mmH2O
0.41 mmH2O
+22.6 %
0.41 mmH2O
+36.0 %
0.30 mmH2O
+50.0 %
0.09 hPa
+80.0 %
0.09 hPa
+25.0 %
+33.3 %
0.03 hPa
41.6
-17.8 %
34.2
41
-3.8 %
42.6
39.1
-4.2 %
40.8
40.5
-1.5 %
39.9
