Alpenföhn
Blacknoise
Wing Boost 3
B12x-PS-BL PWM ARGB
122 g
120 g
400 U/min
1050 U/min
1500 U/min
60.6 CFM
58.1 CFM
103.0 m³/h
98.7 m³/h
1.80 mmH2O
22.0 dBA
21.2 dBA
4.7 V
3.3 V
2.0 V
443 U/min
386 U/min
174 U/min
570 U/min
1075 U/min
1491 U/min
477 U/min
49.3 CFM
+34.6 %
36.6 CFM
23.5 CFM
+0.2 %
23.5 CFM
23.5 CFM
+2.0 %
23.9 CFM
20.7 CFM
+10.2 %
22.8 CFM
83.7 m³/h
+34.6 %
62.2 m³/h
39.9 m³/h
+0.3 %
40.0 m³/h
39.9 m³/h
+0.3 %
39.8 m³/h
35.1 m³/h
+10.3 %
38.7 m³/h
1.63 mmH2O
+45.5 %
1.12 mmH2O
+16.4 %
+22.0 %
0.40 mmH2O
+77.5 %
0.16 hPa
+45.5 %
0.11 hPa
+16.7 %
+20.0 %
+75.0 %
44.6
-13.2 %
38.7
47.3
-19.9 %
37.9
45.7
-14.4 %
39.1
43.3
-14.5 %
37
