Alpenföhn
Fractal
Wing Boost 3
Prisma AL-12PWM
122 g
167 g
400 U/min
500 U/min
1050 U/min
1.9 W
60.6 CFM
85.7 CFM
103.0 m³/h
145.7 m³/h
2.80 mmH2O
22.0 dBA
32.0 dBA
4.7 V
4.5 V
2.0 V
3.8 V
443 U/min
443 U/min
174 U/min
269 U/min
1075 U/min
2001 U/min
477 U/min
550 U/min
49.3 CFM
+55.9 %
31.6 CFM
23.5 CFM
+13.4 %
20.7 CFM
23.5 CFM
+12.7 %
20.8 CFM
20.7 CFM
+4.5 %
19.8 CFM
83.7 m³/h
+55.9 %
53.7 m³/h
39.9 m³/h
+13.4 %
35.2 m³/h
39.9 m³/h
+12.7 %
35.4 m³/h
35.1 m³/h
+4.5 %
33.6 m³/h
1.63 mmH2O
+101.2 %
+16.4 %
+42.0 %
0.40 mmH2O
+52.5 %
0.16 hPa
+100.0 %
+16.7 %
+40.0 %
+50.0 %
44.6
-20.4 %
35.5
47.3
-29.0 %
33.6
45.7
-30.2 %
31.9
43.3
-33.9 %
28.6
  • 269
  • 469
  • 669
  • 869
  • 1069
  • 1269
  • 1469
  • 1669
  • 1869
