Alpenföhn
Alphacool
Wing Boost 3
Rise Aurora
122 g
180 g
400 U/min
1050 U/min
2500 U/min
60.6 CFM
70.0 CFM
103.0 m³/h
118.9 m³/h
3.17 mmH2O
22.0 dBA
31.5 dBA
4.7 V
3.0 V
2.0 V
2.9 V
443 U/min
862 U/min
174 U/min
874 U/min
339 U/min
181 U/min
1075 U/min
2775 U/min
477 U/min
1045 U/min
49.3 CFM
+69.8 %
29.0 CFM
23.5 CFM
+4.0 %
24.4 CFM
23.5 CFM
+0.0 %
23.5 CFM
20.7 CFM
+6.8 %
22.1 CFM
83.7 m³/h
+69.8 %
49.3 m³/h
39.9 m³/h
+4.0 %
41.5 m³/h
39.9
39.9
35.1 m³/h
+6.8 %
37.5 m³/h
1.63 mmH2O
+166.4 %
+19.6 %
0.51 mmH2O
+22.6 %
0.41 mmH2O
0.40 mmH2O
+2.0 %
0.41 mmH2O
0.16 hPa
+166.7 %
+20.0 %
+25.0 %
0.04
0.04
44.6
-6.7 %
41.6
47.3
-13.3 %
41
45.7
-14.4 %
39.1
43.3
-6.5 %
40.5
