Alpenföhn
Thermaltake
Wing Boost 3
122 g
212 g
400 U/min
500 U/min
1050 U/min
60.6 CFM
58.4 CFM
103.0 m³/h
99.1 m³/h
2.41 mmH2O
22.0 dBA
22.3 dBA
Grau
4.7 V
2.0 V
443 U/min
391 U/min
174 U/min
413 U/min
1075 U/min
1950 U/min
477 U/min
49.3 CFM
+48.4 %
33.2 CFM
23.5 CFM
+7.3 %
25.2 CFM
23.5 CFM
+4.2 %
24.5 CFM
20.7 CFM
+0.8 %
20.8 CFM
83.7 m³/h
+48.4 %
56.4 m³/h
39.9 m³/h
+7.3 %
42.8 m³/h
39.9 m³/h
+4.2 %
41.6 m³/h
35.1 m³/h
+0.8 %
35.4 m³/h
1.63 mmH2O
+12.9 %
1.84 mmH2O
+32.8 %
0.5
0.5
0.4
0.4
0.16 hPa
+12.8 %
0.18 hPa
+32.4 %
+2.0 %
+2.0 %
44.6
-16.1 %
37.4
47.3
-22.8 %
36.5
45.7
-21.2 %
36
43.3
-16.4 %
36.2
