Corsair
Silent Wings 3
QL120 RGB
137 g
163 g
150 U/min
500 U/min
1450 U/min
1500 U/min
50.5 CFM
41.8 CFM
85.8 m³/h
1.79 mmH2O
1.55 mmH2O
16.4 dBA
26.0 dBA
Silber
Halbtransparent
4.1 V
3.0 V
3.9 V
245 U/min
472 U/min
206 U/min
244 U/min
1411 U/min
1600 U/min
22.5 CFM
+23.2 %
27.8 CFM
19.9 CFM
+3.6 %
20.6 CFM
17.2 CFM
+11.3 %
19.2 CFM
16.8 CFM
+2.8 %
17.2 CFM
38.3 m³/h
+23.2 %
47.2 m³/h
33.8 m³/h
+3.6 %
35.0 m³/h
29.3 m³/h
+11.3 %
32.6 m³/h
28.5 m³/h
+2.8 %
29.3 m³/h
1.01
1.01
+42.0 %
+42.0 %
+25.0 %
0.40 mmH2O
+1.0 %
+39.3 %
+39.3 %
+22.6 %
36.8
-4.2 %
38.4
41.8
-8.4 %
38.3
40.5
-11.4 %
35.9
40.6
-11.8 %
35.8
