Silent Wings 3
Light Wings PWM HS
137 g
210 g
150 U/min
300 U/min
1450 U/min
2500 U/min
1.4 W
5.4 W
50.5 CFM
52.3 CFM
85.8 m³/h
88.9 m³/h
1.79 mmH2O
2.60 mmH2O
16.4 dBA
31.0 dBA
4.1 V
3.9 V
608 U/min
565 U/min
206 U/min
244 U/min
1411 U/min
2489 U/min
248 U/min
22.5 CFM
+44.4 %
32.5 CFM
19.9 CFM
+7.6 %
18.5 CFM
17.2 CFM
+9.9 %
18.9 CFM
16.8 CFM
+5.6 %
17.7 CFM
38.3 m³/h
+44.4 %
55.3 m³/h
33.8 m³/h
+7.6 %
31.4 m³/h
29.3 m³/h
+9.9 %
32.2 m³/h
28.5 m³/h
+5.6 %
30.1 m³/h
1.01 mmH2O
+42.3 %
+42.0 %
+77.5 %
0.40 mmH2O
0.5
0.5
+41.5 %
+39.3 %
+74.1 %
+2.0 %
36.8
-8.4 %
33.7
41.8
-24.4 %
31.6
40.5
-21.0 %
32
40.6
-24.4 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
