Silent Wings 3
Light Wings PWM
137 g
205 g
150 U/min
100 U/min
1450 U/min
1700 U/min
0.8 W
4.6 W
50.5 CFM
41.5 CFM
85.8 m³/h
70.5 m³/h
1.79 mmH2O
1.66 mmH2O
16.4 dBA
20.6 dBA
4.1 V
3.9 V
369 U/min
350 U/min
206 U/min
244 U/min
1411 U/min
1680 U/min
134 U/min
22.5 CFM
+49.9 %
33.8 CFM
19.89
19.89
17.2 CFM
+12.6 %
19.4 CFM
16.8 CFM
+10.2 %
18.5 CFM
38.3 m³/h
+49.9 %
57.4 m³/h
33.8
33.8
29.3 m³/h
+12.6 %
33.0 m³/h
28.5 m³/h
+10.2 %
31.4 m³/h
1.01 mmH2O
+42.3 %
+42.0 %
+42.0 %
+22.0 %
+41.5 %
+39.3 %
+39.3 %
+22.4 %
36.8
-19.8 %
29.5
41.8
-29.2 %
29.6
40.5
-22.2 %
31.5
40.6
-20.2 %
32.4
  • 350
  • 550
  • 750
  • 950
  • 1150
  • 1350
  • 1550
