MSI
Silent Wings 3
MEG Silent Gale P12
27.5 mm
137 g
209 g
150 U/min
1450 U/min
0.7 W
1.4 W
50.5 CFM
56.2 CFM
85.8 m³/h
95.5 m³/h
1.79 mmH2O
2.21 mmH2O
16.4 dBA
22.7 dBA
4.1 V
5.5 V
3.9 V
4.3 V
906 U/min
742 U/min
206 U/min
194 U/min
244 U/min
186 U/min
1411 U/min
1980 U/min
512 U/min
22.5 CFM
+38.1 %
31.1 CFM
19.9 CFM
+8.3 %
21.5 CFM
17.2 CFM
+28.0 %
22.1 CFM
16.8 CFM
+17.4 %
19.7 CFM
38.3 m³/h
+38.1 %
52.9 m³/h
33.8 m³/h
+8.3 %
36.6 m³/h
29.3 m³/h
+28.0 %
37.5 m³/h
28.5 m³/h
+17.2 %
33.4 m³/h
1.01 mmH2O
+11.0 %
0.91 mmH2O
+14.1 %
+14.1 %
+62.0 %
+10.0 %
0.09 hPa
+14.9 %
+14.9 %
+63.2 %
36.8
-15.2 %
31.2
41.8
-16.7 %
34.8
40.5
-14.6 %
34.6
40.6
-18.5 %
33.1
