Blacknoise
Silent Wings 3
NB-eLoop X PWM B12xP ARGB
137 g
120 g
150 U/min
400 U/min
1450 U/min
50.5 CFM
77.9 CFM
85.8 m³/h
132.4 m³/h
1.79 mmH2O
3.02 mmH2O
16.4 dBA
28.4 dBA
Grau
4.1 V
3.4 V
3.9 V
294 U/min
138 U/min
206 U/min
244 U/min
1411 U/min
2002 U/min
22.5 CFM
+79.9 %
40.5 CFM
19.9 CFM
+25.1 %
24.9 CFM
17.2 CFM
+33.5 %
23.0 CFM
16.8 CFM
+25.3 %
21.0 CFM
38.3 m³/h
+79.9 %
68.9 m³/h
33.8 m³/h
+25.1 %
42.3 m³/h
29.3 m³/h
+33.4 %
39.1 m³/h
28.5 m³/h
+25.3 %
35.7 m³/h
1.01 mmH2O
+41.6 %
1.43 mmH2O
+14.1 %
+16.4 %
0.5
0.5
+41.4 %
0.14 hPa
+14.9 %
+16.0 %
+2.0 %
36.8
-6.5 %
34.4
41.8
-12.7 %
36.5
40.5
-11.4 %
35.9
40.6
-11.1 %
36.1
