Corsair
Silent Wings 3
LL140 RGB
137 g
210 g
150 U/min
600 U/min
1450 U/min
1300 U/min
50.5 CFM
51.5 CFM
85.8 m³/h
87.5 m³/h
1.79 mmH2O
1.52 mmH2O
16.4 dBA
25.0 dBA
Halbtransparent
4.1 V
3.9 V
2.9 V
226 U/min
378 U/min
206 U/min
244 U/min
1411 U/min
1319 U/min
22.5 CFM
+99.8 %
45.0 CFM
19.9 CFM
+42.6 %
28.4 CFM
17.2 CFM
+42.0 %
24.5 CFM
16.8 CFM
+57.6 %
26.4 CFM
38.3 m³/h
+99.7 %
76.5 m³/h
33.8 m³/h
+42.6 %
48.2 m³/h
29.3 m³/h
+42.0 %
41.6 m³/h
28.5 m³/h
+57.5 %
44.9 m³/h
1.01 mmH2O
+68.3 %
0.60 mmH2O
+42.0 %
+42.0 %
+22.0 %
+65.1 %
+39.3 %
+39.3 %
+22.4 %
36.8
-4.1 %
35.3
41.8
-11.7 %
36.9
40.5
-16.0 %
34
40.6
-14.3 %
34.8
