Alphacool
Silent Wings 3
Eiszyklon Aurora Lux Pro ARGB
137 g
200 g
150 U/min
600 U/min
1450 U/min
1500 U/min
50.5 CFM
58.3 CFM
85.8 m³/h
99.3 m³/h
1.79 mmH2O
1.60 mmH2O
16.4 dBA
38.0 dBA
4.1 V
3.3 V
3.9 V
2.9 V
316 U/min
393 U/min
206 U/min
244 U/min
1411 U/min
1499 U/min
22.5 CFM
+103.9 %
46.0 CFM
19.9 CFM
+24.5 %
24.8 CFM
17.2 CFM
+22.9 %
21.2 CFM
16.8 CFM
+43.9 %
24.1 CFM
38.3 m³/h
+103.9 %
78.1 m³/h
33.8 m³/h
+24.6 %
42.1 m³/h
29.3 m³/h
+22.9 %
36.0 m³/h
28.5 m³/h
+43.9 %
41.0 m³/h
1.01 mmH2O
+42.3 %
+77.5 %
0.40 mmH2O
+42.0 %
+25.0 %
0.40 mmH2O
+41.5 %
+74.1 %
+39.3 %
+22.6 %
36.8
-6.5 %
34.4
41.8
-18.4 %
34.1
40.5
-18.3 %
33.1
40.6
-20.0 %
32.5
