Noctua
Silent Wings 3
NF-A14 FLX
137 g
210 g
150 U/min
900 U/min
1450 U/min
1200 U/min
50.5 CFM
68.0 CFM
85.8 m³/h
115.5 m³/h
1.79 mmH2O
1.51 mmH2O
16.4 dBA
19.2 dBA
Beige
Braun
Braun
4.1 V
4.6 V
3.9 V
4.2 V
381 U/min
469 U/min
206 U/min
244 U/min
1411 U/min
1199 U/min
22.5 CFM
+137.4 %
53.5 CFM
19.9 CFM
+65.7 %
33.0 CFM
17.2 CFM
+83.7 %
31.7 CFM
16.8 CFM
+79.7 %
30.1 CFM
38.3 m³/h
+137.3 %
90.9 m³/h
33.8 m³/h
+65.7 %
56.0 m³/h
29.3 m³/h
+83.6 %
53.8 m³/h
28.5 m³/h
+79.6 %
51.2 m³/h
1.01 mmH2O
+11.0 %
0.91 mmH2O
+28.2 %
0.91 mmH2O
+42.0 %
+66.7 %
0.30 mmH2O
+10.0 %
0.09 hPa
+29.3 %
0.09 hPa
+39.3 %
+63.4 %
0.03 hPa
36.8
-7.1 %
34.2
41.8
-1.9 %
42.6
40.5
-0.7 %
40.8
40.6
-1.7 %
39.9
