Lian Li
Cooler Master
UNI FAN SL120 ARGB
Masterfan MF120 Halo
232 g
180 g
800 U/min
650 U/min
1900 U/min
1800 U/min
58.5 CFM
47.2 CFM
99.5 m³/h
1.67 mmH2O
31.0 dBA
30.0 dBA
Silber
Grau
Halbtransparent
3.3 V
2.4 V
412 U/min
166 U/min
98 U/min
590 U/min
1828 U/min
1792 U/min
23.2 CFM
+6.6 %
24.8 CFM
17.7 CFM
+12.3 %
19.9 CFM
15.8 CFM
+27.9 %
20.2 CFM
15.3 CFM
+12.7 %
17.2 CFM
39.5 m³/h
+6.6 %
42.1 m³/h
30.1 m³/h
+12.3 %
33.8 m³/h
26.9 m³/h
+16.7 %
31.4 m³/h
26.0 m³/h
+12.7 %
29.3 m³/h
0.4
0.4
0.40 mmH2O
+102.5 %
0.4
0.4
0.4
0.4
0.04
0.04
+100.0 %
0.04
0.04
0.04
0.04
38.8
-2.6 %
37.8
36.7
-0.8 %
36.4
36.1
-1.1 %
36.5
34.6
-2.8 %
35.6
