Lian Li
Sharkoon
UNI FAN SL120 ARGB
Silent Storm PWM RGB Fan
232 g
168 g
800 U/min
400 U/min
1900 U/min
1400 U/min
2.6 W
58.5 CFM
99.5 m³/h
121.9 m³/h
1.67 mmH2O
1.47 mmH2O
31.0 dBA
34.7 dBA
Silber
2.4 V
1.9 V
412 U/min
506 U/min
98 U/min
54 U/min
1828 U/min
1413 U/min
440 U/min
23.2 CFM
+76.8 %
41.1 CFM
17.7 CFM
+80.4 %
31.9 CFM
15.8 CFM
+93.7 %
30.7 CFM
15.3 CFM
+119.6 %
33.6 CFM
39.5 m³/h
+76.7 %
69.8 m³/h
30.1 m³/h
+80.4 %
54.3 m³/h
26.9 m³/h
+93.7 %
52.1 m³/h
26.0 m³/h
+119.6 %
57.1 m³/h
0.40 mmH2O
+102.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+77.5 %
0.40 mmH2O
+27.5 %
0.51 mmH2O
+100.0 %
+75.0 %
+75.0 %
+25.0 %
38.8
-16.0 %
32.6
36.7
-10.9 %
32.7
36.1
-8.0 %
33.2
34.6
-7.2 %
32.1
  • 54
  • 254
  • 454
  • 654
  • 854
  • 1054
  • 1254
