Lian Li
Corsair
UNI FAN SL120 ARGB
ML 120 RGB Elite
232 g
186 g
800 U/min
450 U/min
1900 U/min
1.6 W
58.5 CFM
58.1 CFM
99.5 m³/h
98.7 m³/h
1.67 mmH2O
2.90 mmH2O
31.0 dBA
30.4 dBA
Silber
3.0 V
2.4 V
412 U/min
510 U/min
98 U/min
450 U/min
169 U/min
84 U/min
1828 U/min
1993 U/min
23.2 CFM
+51.7 %
35.2 CFM
17.7 CFM
+36.6 %
24.2 CFM
15.8 CFM
+49.8 %
23.7 CFM
15.3 CFM
+39.2 %
21.3 CFM
39.5 m³/h
+51.6 %
59.9 m³/h
30.1 m³/h
+36.5 %
41.1 m³/h
26.9 m³/h
+49.8 %
40.3 m³/h
26.0 m³/h
+39.2 %
36.2 m³/h
0.40 mmH2O
+77.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+52.5 %
0.40 mmH2O
+77.5 %
+75.0 %
+50.0 %
+50.0 %
+75.0 %
38.8
-26.5 %
28.5
36.7
-19.6 %
29.5
36.1
-21.1 %
28.5
34.6
-19.7 %
27.8
  • 169
  • 369
  • 569
  • 769
  • 969
  • 1169
  • 1369
  • 1569
  • 1769
  • 1969
