Lian Li
Corsair
UNI FAN SL120 ARGB
QL120 RGB
232 g
163 g
800 U/min
500 U/min
1900 U/min
1500 U/min
58.5 CFM
41.8 CFM
99.5 m³/h
1.67 mmH2O
1.55 mmH2O
31.0 dBA
26.0 dBA
Silber
Silber
Halbtransparent
3.0 V
2.4 V
412 U/min
245 U/min
98 U/min
472 U/min
1828 U/min
1600 U/min
23.2 CFM
+19.5 %
27.8 CFM
17.7 CFM
+16.3 %
20.6 CFM
15.8 CFM
+21.2 %
19.2 CFM
15.3 CFM
+12.7 %
17.2 CFM
39.5 m³/h
+19.5 %
47.2 m³/h
30.1 m³/h
+16.3 %
35.0 m³/h
26.9 m³/h
+21.2 %
32.6 m³/h
26.0 m³/h
+12.7 %
29.3 m³/h
0.40 mmH2O
+152.5 %
1.01 mmH2O
0.40 mmH2O
+25.0 %
0.40 mmH2O
+25.0 %
0.4
0.4
+150.0 %
+25.0 %
+25.0 %
0.04
0.04
38.8
-1.0 %
38.4
36.7
-4.2 %
38.3
36.1
-0.6 %
35.9
34.6
-3.4 %
35.8
