Lian Li
UNI FAN SL120 ARGB
Light Wings PWM HS
232 g
210 g
800 U/min
300 U/min
1900 U/min
2500 U/min
1.4 W
5.4 W
58.5 CFM
52.3 CFM
99.5 m³/h
88.9 m³/h
1.67 mmH2O
2.60 mmH2O
31.0 dBA
31.0 dBA
Silber
2.4 V
412 U/min
608 U/min
98 U/min
565 U/min
1828 U/min
2489 U/min
248 U/min
23.2 CFM
+40.0 %
32.5 CFM
17.7 CFM
+4.3 %
18.5 CFM
15.8 CFM
+19.7 %
18.9 CFM
15.3 CFM
+15.8 %
17.7 CFM
39.5 m³/h
+40.0 %
55.3 m³/h
30.1 m³/h
+4.3 %
31.4 m³/h
26.9 m³/h
+19.7 %
32.2 m³/h
26.0 m³/h
+15.8 %
30.1 m³/h
0.40 mmH2O
+77.5 %
0.40 mmH2O
+25.0 %
0.4
0.4
0.40 mmH2O
+25.0 %
+75.0 %
+25.0 %
0.04
0.04
+25.0 %
38.8
-13.1 %
33.7
36.7
-13.9 %
31.6
36.1
-11.4 %
32
34.6
-11.3 %
30.7
  • 565
  • 765
  • 965
  • 1165
  • 1365
  • 1565
  • 1765
  • 1965
  • 2165
  • 2365
