Lian Li
MSI
UNI FAN SL120 ARGB
MEG Silent Gale P12
27.5 mm
232 g
209 g
800 U/min
1900 U/min
0.7 W
1.4 W
58.5 CFM
56.2 CFM
99.5 m³/h
95.5 m³/h
1.67 mmH2O
2.21 mmH2O
31.0 dBA
22.7 dBA
Silber
5.5 V
2.4 V
4.3 V
412 U/min
906 U/min
98 U/min
742 U/min
194 U/min
186 U/min
1828 U/min
1980 U/min
512 U/min
23.2 CFM
+34.0 %
31.1 CFM
17.7 CFM
+21.6 %
21.5 CFM
15.8 CFM
+39.4 %
22.1 CFM
15.3 CFM
+28.6 %
19.7 CFM
39.5 m³/h
+33.9 %
52.9 m³/h
30.1 m³/h
+21.6 %
36.6 m³/h
26.9 m³/h
+39.4 %
37.5 m³/h
26.0 m³/h
+28.5 %
33.4 m³/h
0.40 mmH2O
+127.5 %
0.91 mmH2O
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
0.40 mmH2O
+102.5 %
+125.0 %
0.09 hPa
+100.0 %
+100.0 %
+100.0 %
38.8
-19.6 %
31.2
36.7
-5.2 %
34.8
36.1
-4.2 %
34.6
34.6
-4.3 %
33.1
